Draw-Bar Cover Protects Milling-Machine Operators
May 1, 2017Comments
Milling machines can endanger operators should they come into contact with the machines’ high-speed rotating draw bars. Protect operators from this inherent danger by implementing this new draw-bar cover from Rockford Systems, designed to protect workers from rotating shafts 7 ft. or less from the floor or working platform.
The cover guards the turning draw bar with a non-rotating, smooth, welded-steel enclosure, firmly secured to the mill with a ring magnet and a 24-in. zinc-plated steel anchor chain. Simple to install, the draw-bar cover prevents clothing, hair or hands from being grabbed by the moving shaft. The welded-steel enclosure has a 4.95-in.-dia. base and 7.125-in. extrusion, and weighs 4 lb.
Rockford Systems LLC: www.rockfordsystems.com
See also: Rockford Systems, LLC
There are no comments posted.Where to Begin Continuous Improvement of Stamping-Tool Desig...
Thomas Vacca Thursday, February 27, 2025
Automotive Supply Chain Faces Headwinds
Laurie Harbour Monday, February 17, 2025
Can You Provide Guidelines for Designing Progressive Stampin...
Thomas Vacca Saturday, January 25, 2025
