Compact Load Cells Monitor Static or Dynamic Forces
December 1, 2008CommentsBaumer Ltd., Southington, CT, has introduced DLRx load cells, designed to measure force in harsh industrial environments. Featuring IP65/IP67 protection
Offering ideal transverse sensitivity by compensating for noncentrally applied forces, the load cells offer accurate force absorption and precise, low-noise dynamic signal processing during all measuring applications. These sensors can be used to measure compression and tension/compression over the entire conventional force range of 0.5 to 100 kN.
Baumer Ltd.: 800/937-9336; www.baumerelectric.com/usa
See also: Baumer Electric
There are no comments posted.Eliminating Pressroom Waste—One Walk at a Time
Manuel Resendes Tuesday, June 10, 2025
Eren Billur Thursday, March 27, 2025
Industry 4.0 Applications in the Sheet Metal Forming Industr...
From Data to Decisions: How Smarter Factories Will Shape Man...
Matthew Heerey Thursday, March 13, 2025
Plant-Wide Features Introduced in Machine-Monitoring Product
Friday, February 28, 2025
