Sensor Types, and Their Roles in the Pressroom
July 28, 2020
Marcel Ulrich, Product Manager - Customized Applications with Pepperl+Fuchs North America, answers these five questions.
1. What has made metal-sensing inductive products such workhorse tools in pressrooms?
Inductive sensors address key pressroom-sensing requirements better than any other technology. They’re extremely accurate, offering repeatability of a few thousandths of an inch. Their mechanical design, with electronics fully encapsulated, meets the durability demands of the pressroom. Their immunity to lubricant degradation and ingress, as well as shock and vibration, is outstanding. The technology is flexible, with off-the-shelf models available in hundreds of different form factors, and with analog, digital and IoT-friendly outputs. Compared to the cost of a die crash, they’re also extremely cost-effective, with most models available for less than $100. What’s not to like about them?
2. Where do photoelectric or laser sensors fit into the picture?
When sensing-distance requirements, or perhaps wiring considerations, prevent a stamper from embedding an inductive sensor in the die, photoelectric sensors (photoeyes) offer a great alternative. They can be mounted outside of the die yet still monitor workpieces and tooling with pinpoint precision. Visible red or laser light spots make for easy setup, and background-suppression technologies ensure that they only detect the workpiece and not the surroundings. They also cover a much wider scan area than their inductive counterparts. While inductive technology has remained relatively unchanged over the past 25 years, the application-solving capabilities of photoeyes have exploded. Anyone who may have given up on them 10 or 15 years ago should give them another look.
3. Since oil mist or other contaminants can impact the performance of photoelectric sensors, what types of sensors work best in these types of environments?
An underutilized option is the ultrasonic sensor. Ultrasonics use acoustic time of flight to provide presence/ absence, or analog feedback. They monitor process parameters such as lube-tank level, coil-feed loop tension and coil diameter. Unlike optics-based products, their accuracy is completely unaffected by glare, color variances and oil misting. Be aware, however: Compared to other sensing technologies, an ultrasonic beam is somewhat wide. So, it performs best in open areas.
4. As stampers look to automate quality and inspection functions, using data captured from linear camera systems, what are some of the most popular applications for these systems?
Linear camera systems take optical “slices” of a target object and piece them together via software to provide high-accuracy part profiling. They’re best suited for larger operations, such as stamping a car door, and are useful at every process stage. At the front end they profile the blank, while also monitoring the feed-stack height. Inside of a press, they ensure that no trimmed scrap remains in the die after the workpiece is transferred. And, after the stamping operation, the same camera system scans the rack to ensure that the rack itself, and its retaining bars, are in place for loading.
5. Where else do you see shop-floor data collection expanding?
I think that the ambiguities of Industry 4.0 as it relates to sensors are clearing up a little. And, metal formers will benefit. Only a year or two ago, stampers thought of IO-Link sensors as intriguing and interesting, but now they’ve moved to the point where many stamping operations are applying this technology, and finding it helpful. Field-level sensors with IO-Link capabilities are becoming increasingly commonplace, as is the comfort level with collecting and utilizing sensor data to monitor and improve processes. Sensing technologies connected to IO-Link masters provide real-time industrial control. The masters connect to industrial networks via Ethernet/IP, Modbus TCP and Profinet. Time-critical, control-relevant data move to a PLC, while configuration and diagnostics data bypass the PLC and flow directly to the cloud, where the information is accessible easily and securely to authorized users and processes. MF
Industry-Related Terms: Blank, Color, Die, Form, LASER, Scrap, Ultrasonic, Stamping
See also: Pepperl+Fuchs, Inc.
