Hydraulic Press Solutions Including Automation, Custom Applications
July 30, 2024Comments
Greenerd Press & Machine Co.
Booth S30059
Greenerd Press & Machine Co. highlights its extensive hydraulic press offerings and automation capabilities. Application experts and design engineers are available to discuss specific user applications and press requirements. The company designs and builds custom hydraulic presses with automation solutions for a range of industries and applications. One example demonstrating these capabilities is a 2500-ton hot forming press (pictured). Greenerd designed, engineered and turnkey-installed this press, which features 10-sq.-ft. heated platens maintaining 500 F surfaces to +/- 5 deg. The press comprises a seven-press order. The 2500-ton press features an innovative mold-transfer system that significantly improves the ergonomic and safety dynamics for operators, and reduces the press idle time between cycles.
Greenerd is a Fanuc America Tier One Industrial Authorized Robot System Integrator. The partnership gives Greenerd full access to the comprehensive offerings of Fanuc robots including all models, training and support, leading to fully integrated production systems in short timeframes.
See also: Greenerd Press & Machine Co., FANUC America, Inc.
