Eagle Press & Equipment Brings Gap-Frame Presses to its Tenn. Showroom
February 4, 2022Comments
Eagle Press & Equipment Co. Ltd., Windsor, Ontario, Canada,
an Isgec Group Company, has begun to showcase its stock line of Rhino GZ-series
gap-frame presses at its Eagle Press America Inc. showroom in Portland, TN. Rhino GZ presses are available from 80 to 315-ton
(or more) capacity and boast a rigid frame fabricated from tested steel, stress
relieved to ensure uniform distribution and reduce angular deflection to maintain
alignment of the top and bottom dies.
To ensure accurate slide guiding, Rhino GZ presses employ extra-long six-point guiding. And, the presses feature elements specifically designed for vibration-free force transmission--crankshafts, connecting rods, a quill-mounted flywheel and the gear-and-pinion system. In addition, a wet-type clutch and brake unit maximizes brake-liner life and simplifies maintenance.
Use Rhino GZ series for shallow drawing, forming, piercing, notching, trimming and bending operations.
See also: Eagle Press & Equipment Co. Ltd.
Fagor Arrasate Begins Expansion of Its Mondragón, Spain Plan...
Friday, July 11, 2025
Andritz Schuler Workshop Highlights Service and Product Capa...
Friday, June 20, 2025
