David Diaz-Infante David Diaz-Infante
Servo Press Scientist
Leveraging Servo Press Motion Profiles
October 23, 2024
Have one or more servomechanical presses on the shop floor? If so, take to heart the four tips offered here to optimize productivity without impacting part quality or tool life.
Imagine achieving significant improvements in your stamping line with just a few strategic adjustments. Advanced servo press motion profiles can boost production rates significantly, but many stampers struggle to find the optimum settings. The key: understanding what happens at every degree of the press stroke.
This article explores practical strategies to help metal formers get the most from their servo presses, offering four tips for optimizing performance.
1. Slow Down Only When Needed
Servo-Press-Motion-Profiles-Fig-1A well-known servo press characteristic is the ability to adjust ram speed throughout the entire stroke, a feature that can enhance part quality and extend tool life. This flexibility provides a major advantage over conventional presses, which operate with a fixed speed during the full 360-deg. rotation.
However, we see many metal formers reduce ram speed on their servo presses to arbitrary levels, typically between 120 and 180 deg. of press-shaft rotation. While slowing down can reduce impact speed and minimize reverse tonnage and snapthrough, it should be applied selectively. Excessive deceleration can decrease the production rate unnecessarily, while insufficient slowing can harm press and tool life, and affect part quality.
Thus, the key to dialing in the optimum speed for the highest production rate (Fig. 1) is defining the points throughout the stroke where slowing down proves beneficial. For example, look for angles where piercing or blanking occur, where lifters or risers are initiated, and where extra feed time is required.
Excessive speed during piercing or blanking will increase snapthrough and reverse tonnage. Speeds too high during the upstroke can lead to part instability, disrupting the feed process and potentially causing tool wear. Excessive ram speed during part feeding or transfer can result in inadequate time for these processes. And, excess speed at the critical angle can lead to excessive braking angle. Meanwhile, setting ram speed too low during drawing can create improper material flow for certain combinations of material, tool steel and lubricant.
2. Look at the Load Signature in the Tonnage Monitor
Servo Press Motion Profiles Fig 2Metal formers should use the load-signature analysis to help define servo press speeds. Almost all servo presses have a tonnage monitor providing peak-load detection, a great tool for protecting the press and the tool from excessive loads. The most useful tonnage monitors are capable of providing load-signature analysis. Load signature not only indicates peak load, but it tracks the load evolution throughout the press stroke, useful for characterizing the process and for detecting anomalies.
By looking at the load signature, operators can understand at which position in the stroke the force builds up, or when it drops dramatically, indicating material breakage. A simplistic but useful way to approach this: Look at the peaks and valleys in the load signature or at negative tonnages. The negative values should stay within press limits, and the smaller the peaks and valleys, the better. The opposite is detrimental for the press and the tool.
Fig. 2 illustrates using signature analysis to correct an application running at 60 strokes/min.
3. Use the Pendulum Mode Wisely
Servo Press Motion Profiles Fig. 3Pendulum mode on a servo press can increase production rates significantly by using only a partial rotation for each stroke rather than a full 360 deg., reducing cycle time. However, metal formers should take care when designing a pendulum profile, especially in regard to feed angle. An insufficient feed angle can cause erratic feeding, leading to misfeeds or forcing the press to slow down in order to allow the material to feed properly. Conversely, an excessive feed angle results in a larger pendulum motion that slows production due to wasted degrees in the press cycle.
If the resultant pendulum is too high, close to a 360-deg. rotation (depending on the profile generator), a full revolution may lead to higher production rates.
If a tool design includes part risers, be sure to minimize the height of the risers to allow for short forming strokes. Often, risers are higher than needed, leading to long forming windows that may slow production.
Thus, the correct feed angle in addition to a short forming stroke are keys to maximizing pendulum speeds. Depending on the press control, fine tuning may include small decrements to the pendulum height, or precise definition of the feed window in terms of seconds. Keep in mind that, in general, the shorter the pendulum the higher the production rate, but also less time to feed or transfer material.
Fig. 3 compares pendulum and full-revolution profiles. Note the significant reduction of the feed window in pendulum profiles, which requires high-performance feed equipment. Note: Decide whether to use a pendulum or full-revolution profile on a case-by-case basis.
4. Use 100% (or Close to it) of the Programmed Speeds
Once the servo motion profile has been defined and calculated, the maximum production rate then depends on the dynamic capacity of the servo press. However, often stampers run at a production rate lower than the calculated maximum. This might be due to issues observed when running at higher speeds, including part instability, misfeeds, fractures, tool breakage and end-of-line part stacking. While all these issues might seem valid for decreasing press speed, an actual production rate significantly slower than programmed clearly indicates a non-optimum stroke profile.
Rather than decrease press speed during production, metal formers should redesign the motion profile to accommodate any issues encountered. This can become an iterative process until every challenge has been overcome. If the process proves successful, the actual production rate will be close to that of the maximum programmed rate.
A good rule of thumb: Look for a motion profile that achieves a production rate of 90% or more of the programmed maximum rate.
Take a Strategic Approach
In summary, optimizing production rates with servo motion profiles requires a strategic approach. Use pendulum mode effectively by fine-tuning the feed angles, employing load-signature analysis and adjusting speeds judiciously throughout the entire stroke—and not only toward 180 deg. Ultimately, aim for a motion-profile use of 90% (or greater) of the programmed rate.
Successfully implementing these strategies helps to ensure the highest production rates along with consistent quality, thus enhancing overall operational performance. MF
Industry-Related Terms: Blanking, Drawing, Forming, Piercing, Ram, Run, Stroke, Transfer, Forming
See also: Nidec Press & Automation
