Laser-Based Measurement System Ensures Flatness from Leveler Herr-Voss Stamco
September 1, 2008Comments
In operation, the measurement system displays the optimum leveler backup settings necessary to correct the strip-shape defects. These settings can be adjusted manually, or with the push of a button the backup position can be automatically adjusted. www.herr-voss.com
See also: Herr-Voss Stamco
Andritz to Supply Cut-to-Length Line to Olympic Steel in Min...
February 11, 2025
