Varsteel to Retrofit Stamco's Enhanced Leveling Technology
June 1, 2014To produce “stay-flat” material for laser, waterjet and plasma cutting, the Varsteel service-center location in Lethbridge, Alberta, Canada will soon retrofit a Herr-Voss Stamco enhanced leveling technology (ELT) leveler to an existing cut-to-length line. The ELT retrofit will process material to 96 in. wide and 0.5 in. thick.
See also: Herr-Voss Stamco
Automatic Feed Introduces Automated Change Tables for Use wi...
December 16, 2020
