Control-Reliable Valve for Cylinders
October 1, 2014
Ross Controls
Booth B1107
Ross Controls will showcase its new line of four-way control-reliable valves for double-acting cylinder or cylinder press applications. The CM2 series is a Category 4 PL e device and offers a self-contained dynamic monitoring system, valve fault lockout for added safety and independent reset for precise control of hazardous operations.
CM2 valves feature built-in tamper-proof silencers and optional pressure-switch feedback signals to the machine controls. The flexible base-mounted design can be used independently or in multiple-manifold configurations. Ideal for moveable barrier guards, critical clamping operations or cylinder press control, the CM2 series is available in port sizes from ¼ to ¾ in., in a variety of thread types.  www.rosscontrols.com
See also: Ross Controls
