Efficient, Automated Scrap Removal
September 1, 2010
Prab Quick Return conveyorsPrab, Kalamazoo, MI, introduces Quick Return (QR) conveyors that gently propel material forward without vibration or springs. A low-horsepower design coupled with permanent lubrication minimizes operating cost. The units suit single-press, dedicated units or can be used as a transfer system for plant-wide applications over long distances.
Single units can range from 8 to 40 in. wide and as long as 60 ft. Conveying capacity peaks at 60,000 lb./hr., with load capacity to 2000 lb. and a maximum speed of 20 ft./min.
Prab: 269/382-8200; www.prab.com
Industry-Related Terms: Transfer
See also: PRAB, Inc.
