Two Coil-Fed Press Lines Headed to Lear Brazil
February 1, 2013CommentsTwo compact coil lines (SpaceMaster units from Coe Press Equipment, Sterling Heights, MI) are on the to Lear Brazil, accompanying a pair of Stamtec presses equipped for progressive-die stamping of automotive components. The coil lines, which unwind, straighten and feed coil stock, can handle stock from 0.030 to 0.156 in. thick and 3 to 32 in. wide.
