Gizmos and Gadgets for Feed Monitoring: Patient Clear-Headedness Trumps Rushed Bumbling
April 1, 2012
The hardest part of any serious sensor application lies in its starting point. It’s easy to become overwhelmed by urgency in the pressroom and toolroom, and rightly so. No one wants the same die issue to ever again express itself as a die repair or scrapped parts. This is one of those clear examples where patient clear-headedness als trumps rushed bumbling.
Let’s look at a very common photoelectric-sensor application and see if we can agree that, despite its popularity, external sensor mounting cannot possibly be the right choice. Your die arrives in the pressroom without sensors on it, never mind why. Wisely, you decide to, at the very least, install a feed sensor to check strip progression. This very point in time is akin to the famous Yogi Berra quote, “When you come to the fork in the road, take it.”
You have two choices as to how to implement the sensor. The clock is ticking, production needs parts and everyone appears to lack patience for anything deemed complicated. So, like most in your situation you choose to install the feed sensor externally rather than within the die.
Some of the most creative, convoluted, homemade gizmos I have ever encountered are of this variety. Namely, a magnetic clamp holding a diverse array of interconnected steel rods extending into space to position the photoelectric sensor just right, in order to detect the arrival of some strip or part feature at the end of the feed cycle.
“But we saved time and money doing it this ,” is the typical rationalization for these devices. From shop to shop where these homemade gadgets find use, the initial thinking usually centers on a promise to have a die built and running sooner than is realistically possible. The toolmaker (we’ll call him “Bill”) promises to ensure that the gizmo will work for the first few runs, and then, when he has the time, will mount the sensor within the die.
Well, you know the rest of this story. With each setup, Bill must head into the pressroom and patiently work for several minutes, sometimes an hour, to get the gizmo to work. Over time he becomes quite skilled at making the critical adjustments needed, and even appears willing to come in on nights and weekends, as needed, to perform these adjustments.
Meanwhile, the shop takes in six more dies that also lack feed sensors. Thus, the common logic becomes to have Bill be available to tweak all seven dies and their external feed sensors. He complains, is provided an assistant to help, but eventually becomes aggravated and quits, as does his assistant. Panic, sweat, yelling and even cursing ensue as the company scrambles to hire and train Bill’s replacement.
In retrospect, does this scenario—locating the feed sensor on the outside of the die—really save time and money? Keep in mind that even if Bill makes the proper adjustments, once he walks a who’s to say that the gizmo won’t inadvertently (or perhaps purposefully) get bumped out of adjustment?
The above scenario has been playing out in hundreds of stamping shops for decades.
Many shops proudly describe to visitors their homemade mechanical wizardry invented over the years to accommodate external feed monitoring. Never mind that only one toolmaker can make the wizardry work, as it’s often too cumbersome and difficult for most anyone else to master.
If this sounds like your pressroom, please take a deep breath, step back and ask yourself: Is the entire creative process needed to develop external feed-sensing installations actually costing more time and money than what’s being saved? Spending a few days to properly prepare dies to accommodate in-die feed sensing will typically pay off quickly and easily. Just how many Bills do you think are out there willing and able to perform near-surgical adjustments on external feed sensors? And, should you luck out and find one, what are the odds that he will hang around long enough to keep the externally sensed dies running properly? MF
Industry-Related Terms: Die
Technologies: Coil and Sheet Handling, Sensing/Electronics/IOT
