Two Years,Two New Press Lines
April 1, 2010Over the last two years, the Vogelsang Corp. manufacturing
From its 50,000-sq.-ft. plant, which the company moved to in 1990, Vogelsang specializes in the manufacture of non-threaded fasteners. It also specializes in multislide and rollforming. But in 2008 its focus shifted, when it received a directive to grow its tubular-parts manufacturing capacity using a metalforming process developed by the German parent.
“Since 2002, Jöerg Vogelsang in Germany has been focused on a process its engineers developed to manufacture anti-vibratory products—a process that replaces the use of highly machined cut tubing,” says Dale Stuban, vice president and general manager of the New Jersey operation. “Instead, we stamp the product in the flat, wrap it and clinch the longitudinal seam, all in the press. Our parts are stronger in compression than is tubing, due to the grain direction of the material, and we eliminate a host of secondary operations.”
A Dynamic Duo of Press Lines —One New, One Refurbished
To successfully integrate the German-engineered process into his facility, the plant invested in two new press lines, the latest centered around a refurbished 400-ton Bliss press along with a new servo feeder (from Cooper-Weymouth, Peterson) and refurbished Brown & Boggs straightener. All of the equipment was purchased through local distributor Wenco Machinery, Ringwood, NJ. Full production for the new line begins in April of this year.
The 400-ton line joins
The CWP ServoMax SE servo feed includes matte chrome rolls, 500-job memory and a hand-held remote jog pendant, and boasts roll-position accuracy to ±0.002 in. Vogelsang’s model offers maximum stock width of 18 in. and full-width thickness capacity to 1⁄8 in. And, its Stamtec S2-series straightside press generates as much as 220 tons of force, 50 to 120 strokes/min., 6.3 in. of stroke length and a bolster measuring 72 by 48 in. Sideframe opening is 31.5 by 19.7 in.
“The Stamtec line was added to our equipment list strictly for the anti-vibratory products, to process steel sheet less than 2 mm thick and parts 4-in. dia. and smaller. Larger bushings run on the 400-ton line,” says Stuban, “to ¼ in. thick and 7-in. dia., since that press has more available stroke length.”
The newest job to run on the 400-ton line stamps and forms 4-in.-dia, by 4 in. long bushings from 0.130-in. steel. “The part has windows in it,” Stuban shares, “and we also knurl and profile the inside and outside edges, all done in the flat before we wrap and clinch in the press.”
Together the two new lines account for about 15 percent of the company’s overall revenue, and Stuban expects that percentage could double in the next couple of years—hence the likelihood of a third press to be added to the family.
