Corrosion Protection
June 1, 2018
Cortec Corp.’s FlashCorr VpCI, a blend of surfactants, chelating agents and corrosion inhibitors, protects metal surfaces from corrosion. It can be applied to sand-blasted, water-blasted and wire-brushed surfaces to stabilize and protect against flash corrosion before application of primers, paints and protective coatings. The product reduces application costs and improves adhesion, thus allowing effective and long-term performance of protective-coatings systems. Applications include salt spreaders, snow plows, blowers, boats, commercial vehicles, etc. It also is highly recommended for protection of machinery and engine blocks as well as marine equipment.
Cortec Corp.: www.cortecvci.com
See also: Cortec Corporation
Technologies: Materials
