Powder-Coated Tubing Allows Simplified Welding
November 1, 2008CommentsAtlas Tube, Inc., Chicago, IL, now manufactures powder-primed tubing using the Epox Z Kote process that accomplishes high-speed
A unique benefit of this tubing is the ability to weld directly through the coating without any special preparation or breathing apparatus. Additionally, welding spatter does not stick to the primer, further reducing surface-preparation cost.
The tubing is manufactured in accordance with ASTM A500 and ASTM A513 standards and is available in square sizes to 7 by 7 in., rectangles to 10 by 4 in., and rounds to 8.625-in. OD.
Atlas Tube, Inc.: 800/265-6912; www.atlastube.com
See also: Atlas Tube
Technologies: Materials
There are no comments posted.Aluminum Sheet Alloys
Eren Billur Monday, October 27, 2025
New Packaging Film Prevents Corrosion, Discoloration on Meta...
Friday, February 12, 2021
Heating Helps Forming, Part 1: Hot Stamping of High-Strength...
Eren Billur Wednesday, July 29, 2020
